What is all needed for a/c?
wide_s14
Car: 1992 Nissan 240sx
I have a s14 with the redtop s13 sr and I was wondering what is all needed to make it have a/c?Also if you know any deals on any wide 5zigen rims leave me a response.Thanks for your help.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
All you need is the stock a/c system that comes in the s14. The wires to splice together can be found on fresh alloy. The S14 KA compressor bolts right up to the redtop a/c bracket with all four bolts. You even use the same a/c compressor wire that comes off the chassis.
wide_s14
Thanks.I think you know my friend Adam Huff from work.Well your car is really nice and I was wondering if you know how to tune the afc?E-mail me at [email protected] also thanks again.
deviant
Car: 95 nissan 240sx se
ItzGenX wrote:All you need is the stock a/c system that comes in the s14. The wires to splice together can be found on fresh alloy. The S14 KA compressor bolts right up to the redtop a/c bracket with all four bolts. You even use the same a/c compressor wire that comes off the chassis.
probably a stupid question, but will this also work for a blacktop s14 sr in an s14?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
I welded the SR fittings onto my KA lines and ran the SR compressor. The clutch was just hooked up to a switch that hit it with 12volts when I turnned it on.
If you do that be sure to replace your dryer and have the system evacuated before you re-fill it.
It worked great and blew very cold, the only problem I found was that you HAVE to wire a fan to the same switch, otherwise you can have big problems... like hole in the hood problems.... trust me
I never could figure out how to get my S14 compressor to bolt up to the SR.
Paul
wide_s14
What do you mean the clutch was hooked up to a switch?
Silvia007
Car: 93 Nissan 240SX SE Fastback
Wide_S14, the A/C compressor has a electric clutch that engages the compressor when you supply power to it.
wide_s14
Ok I gotcha.
