e_c »
https://forums.nicoclub.com/e-c-u14217.html
Tue Aug 30, 2005 7:38 pm
the theory above is good, shift higher so that the new gear shifted into is higher in the powerband... that is good but you have to remember that you also want it to be in the power band where your acceleration is better... for instance, you acceleration from 5000-5500 is probably the best acceleration in the whole power band, as it comes to hit top hp, then after top hp, you lose power, and acceleration, so if your shifting too high, the acceleration is lower than it could be in the next gear if you had shifted earlier, sorry if that doesnt make sence, i might read tomarrow and be like WTF was i thinking...
