IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Nov 14, 2003 4:44 pm
the mast is the metal part that extends [the actual antenna]
at the base of the metal mast, there is a white plastic cogged cord that get ravled and unravled from a spool at the base of the power antenna unit [the circular part at the bottom]. when you turn the antenna [radio] on, the motor feed the plastic cord off the spool, and this raises the antenna.
your plastic cord is broken. it requires removal of the unit, opening it, removing the antenna and broken cord, and installing a new unit.
replacement of the mast is cheap and difficult [if you havent done it before]
replacement of the entire power antenna unit is easier and more expensive.
