What is a good compression test for the KA24DE?
Daemos
Car: '03 Spec V
I'm looking at a car right now, and I know the compression test results, they are the same across each cylinder, but I was wondering what the numbers should be, and what would be the problem if they are too high or low...
btw each cylinder reads 140...
MikeMurphy
Car: Guess
was the car warm?
silkk
Car: 94 B13
89 S13
07 S2000
140 sounds right if the car was cold
keepingthe240
I'm doing a compression check in a few weeks. What should the numbers be?? And how would i know if there good enough to handle a turbo??
ftrs13
Car: KATs
just curious, if one were to not disconnect the fuel pump fuse, and do the compression check while injecting gas in the cylinders, how would the compression change?
Jhay
I believe it should be close to..umm 170 or 180..
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Sideshowbob -
KADE #s should be 179psi "standard", 151psi "minimum", no more than 14psi diffeence across all 4 cylinders.
Warm motor, throttle held wide open, fuel pump disconnected, good battery, minimum 300rpm.
ftrs13 -
It "washes" the oil off the cylinders and causes progressively worse readings as you go down the line...i.e. #1 may seem OK, but #2 will read lower, #3 even lower, etc...typically.
You can't gain any info from a comression test if it was performed impoperly..you have to repeat the test to know anything.
- Brian
ftrs13
Car: KATs
thanks, this brings me new hope
keepingthe240
I thought i was talking to a walk!
