I don't have a Versa anymore. If I did it would be my daily and Springs would be all I got.carlos15 wrote:yahh do you have coilovers or springs?
i was about 1.5* positve before the alignment, i am now anout 1.5* negetive. i also have camber adjustable top mounts.biggie wrote:^You probably wouldn't be able to get to factory settings as is then, negative camber is the result of lowering, if you are ok with running it (possibly eating tires faster) then no need for camber kit.
.biggie wrote:If you have camber plates then you have a 'camber kit'. So it is more adjustable than factory.
biggie wrote: Weird that you had positive camber after coilover install.
