what is a butterfly?
jepree
Car: 1995 Nissan 240sx
i hear you guys talkin bout it all the time and im not the gearhead you guys are and i was just wondering if you guys could help?
dkdeleon68
Car: 1991 240
this will show u.they are in the intake and they are controled by the swerl control valve and vacuum
dkdeleon68
Car: 1991 240
and another pic
uncle_louie83
Car: 1993 Nissan 240sx Coupe
hehe...i removed mine...idle is ok i guess...but id keep them in...cause there is a low end power loss...like under 3700 rpms you can feel the difference....once u hit 4k your fine...but id keep them if i was you.
lewis
jepree
awesome thanks guys!
s1ndicate
sorry had to do it Surprised no one else has done it, but they nailed it on the head.
NismoGreg
Car: '93 s13 fastback se, '87 200sx se v6,'91 integra ls
Automatic ka's dont even have butterfies in the intake mani
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
dkdeleon68 wrote:and another pic
Actually those are secondary butterflies, the primary butterfly is the throttle body plate
goober240sx wrote:Automatic ka's dont even have butterfies in the intake mani
I’m an auto KA, and I have one of those nifty air restrictor thingies
InsanityInc
Are the secondary butterflies default open or closed?
Checkered-Member
InsanityInc wrote:Are the secondary butterflies default open or closed?
From my understanding, they are angled at low rpm then open wide at higher rpms, it has to do with accelerating the air into the engine at low rpms to produce more torque
on a hot day with A/C i can feel them open up around 4K
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
ok bringing this out of the dead but im about to put an s13 motor in my s14 cause i blew my rod bearing, and im using the s14 distributor, exhaust mani, but leaving the s13 intake..
now the secondary butterflies, am i going to be able to hook their vacuum up and do they even have a vacuum port somewhere that has to be hooked up? or is it part of the motor (hopefully not unplugged by previous owner then)
tnxMarko
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
The secondary butterflies are pulled closed by vacuum. If their control pot vacuum line was disconnected they would stay open all the time.
