Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Jul 14, 2004 6:52 pm
Possible, but a huge pain in the rear and not worth the effort.
Not only do you have to add the rack, the hydraulic lines, and the different P/S pump...but you also have to add the steering wheel hub with the sensor and hook up all the myriad wiring.
All for a system that's barely noticeable even when it's working. In very hard grip cornering I can feel a little bit of rear motion as the toe adjusts, not a bad thing, but it's very slight.
As for its alleged detrimental effects on drifting, I don't drift very much, but I haven't felt it be a factor on the occasions I have.
