What injectors fit? VG30E...
Discuss topics related to the VG and VE series engines.
Jrev808
Car: 1991 Nissan HB 4x4
Hello gentlemen, need your help please...I am doing a remote mount turbo system on my 1991 HB 4x4 with VG30E. I need to know if I can use injectors from a z32 turbo? something else maybe? What is a direct fit into my engine please. I cant find specific injectors for my truck. thanks for your help!
Modified by Jrev808 at 6:27 PM 3/18/2009
Jrev808
nobody knows??? =(
please...
TJcars2
Car: '87 Acura Legend
Any from a VG30 I believe.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
If your truck has the phase 1 side feed injectors then you can use the early Z32 injectors. I'm pretty sure that model year will have the phase 1 injectors but I'm not positive. Do you have them out? If so, can you take some pictures and I can tel from there.
Jrev808
I was thinking the same thing. I think ones from 90-92 300zx will fit my 91. Those stock 300zx ones are 370cc. I think that may be sufficient. I could also get aftermarket ones for a 90-92 z32 then right? like if I need 440cc or something...
I will try to get pics...
mtcookson
1992 Iinfiniti Q45
and much much more
Mostly just depends on your power goals. The 370's should be good for at least a bit over 300 hp.
Jrev808
I have stock injectors from a 1991 z32. also have the fuel rail if i need to custom fit that... but i just found out they are stock injectors from a nonturbo. =(
atleast i can test fit these and the correct ones can be drop in. so youre pretty sure I can get the z32 ones to fit huh? that would be great. I know youre the expert. Thanks!
BTW... my goal is approx 300hp.
Timmy.V
Car: 1972 datson 510,1992 300z,1969 fastback mustang,1970 fastback mustang
You might want to check out vgpowered.com in the forums under feul and engine mangement.Lots of info on what cars you can get them off of and sizes of injector.anywhere from 340s to 680s.
Jrev808
yeah. I have checked out vgpowered. everyone there talks about using the z31 rail and injectors. cant find info on using the z32s. We will fin dout soon i hope. Finishing up my suspension now...
mtcookson
1992 Iinfiniti Q45
and much much more
I'm going to try getting some pictures of the correct injectors tomorrow. If they have a square plug though I'm 99% sure they'll swap over just fine. I'll get some pictures of the body of the injector for you to compare just to be sure.
Return to “VG30 / VE30 Forum”
