what injector rail will work for 550cc injector ka24E?
jongonzoS13az
Car: 90 240sx
what injector rail will work for 550cc injector ka24E? im having trouble finding aftermarket parts for the single cam what injector system will work?
WDRacing
Do you mean what fuel rail do you have to use for top feed 550cc injectors? If thats the case, then the stock fuel rail should work just fine.
If you want a better fuel rail, look up the "project Silvia" fuel rail on google. It's cheap and works with ALL top feed injectors.
The key is to remember that you need top feed high imp injectors. Where the KA24DE uses sidefeed pieces of crap.
WD
jongonzoS13az
Car: 90 240sx
ok thanks man
