NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Sep 28, 2005 4:30 pm
Ok how it works is it takes air from the intake tube bypassing the throttle plate. It needs this air to run. Once the car is at full operating temp that is the only source of air at idle. If you have the tps unplugged that screw has absolute control of all air getting into the engine. Now if you screw it all the way in and the engine is still idling that means it is getting air from somewhere else. These places can be any number of sources. If the Aux air reg does not close after the car warms up that could be one place. To determine if thats it , while the car is idling pinch off the 1 inch hose going under the intake manifold at the front. This hose is coming off the intake tube. If the car now dies the aux air regulator is stuck open. NOTE the car MUST be at full operating temp when doing this or even adjusting the idle as you were.
If that was not your problem then you may have a vaccum leak somewhere.
