Q45tech wrote:If you had a MAGIC supercharger that didn't take power from the engine you were boosting you would find that a turbocharger is less efficient [than you think] as the restriction in the exhaust REMOVES a roughly equal amount of power potential plus the close coupling of the compressor wheel actually makes the output air hotter per equal psi boost due to radiation and conduction thru the common shaft.
Turbos do use up some power by restricting the exhaust flow, but they also use "free" energy in the form of heat that would otherwise just go down the exhaust. Temperature drops of 150-250F are typical pre/post turbo. In the late 80s, F1 cars made 1300-1400hp in qualifying trim with turbos from 1.5L while top fuel cars make 5000-6000 hp (roughly 4X the power) with superchargers and 5.5 times the displacement, and F1 cars had two significant handicaps compared to the top fuel cars. F1 cars used gasoline with limited octane compared to nitro that top fuel cars use (which allows them to run much higher boost pressures), and F1 cars had to stay together for a much longer period of time than a 4.5 second quarter mile pass. There's a reason all the F1 cars used turbos rather than superchargers back then.
They don't use as much power.
The majority of heat in an intake charge on a car with forced induction is from compression. The heat transfered from the exhaust side of the turbo is minimal by comparision. Air is going through that little compressor housing too fast to transfer much heat. Since turbos often have more efficient compressors than superchargers, outlet discharge temperatures for turbos can easily be cooler than a supercharger for a given level of boost. In any case, adequate intercooling can bring the intake charge down to near ambient temperatures on either application.
Quote »The difference is that the engine has to make the extra 10-15 HP to turn the supercharger so this amount gets absorbed and never shows up at the flywheel.The downside of turbos is the restriction allows the exhaust valves [valve seats, stem seals, heads around the exhaust ports to get hotter because the backup of heat doesn't leave as fast.[/quote]
That is a drawback of turbos, and why I'm generally not a big fan of adding turbos to cars that haven't been designed for them at the factory. You do get a lot of heat on the exhaust side of the engine, particuarily if you use a "small" turbo, which most people do since a non-turbo motor usually isn't strong enough to run the high boost levels where "big" turbos are needed. Since the Q45 has sodium filled exhaust valves (early ones at least), it might be a better candidate for some for turboing.
Quote »Then there is the life of the turbo vs the life of the supercharger and the fact that the turbo may spin 2-3-4 times faster than a supercharger.[/quote]
Modern water cooled turbos are pretty dang reliable if they're maintained (not shut down immediately after 10 laps on a racetrack and regular oil changes), and not abused (overspun by running at boost levels way above stock). Most turbo failures I hear of these days are people who don't take care of them, or are from using a "hybrid" turbo somebody built in their garage from spare parts. I've personally got about 350K turbocharged miles without a failure, and my cars spend a lot of time racing in various venues, so I'm a lot harder on my turbos than the average user. I'd guess the average lifespan of a turbo is a lot longer than the transmission or chain guides of an early Q.
Quote »It is great to see all these cars going back to supercharging.[/quote]
The positive displacement blowers that are showing up in the last few years are a nice application for a lot of cars. An eaton putting out about 5 psi would probably be a nice upgrade for a Q45 (until the tranmission got unhappy anyway.) The instant torque you get from a positive displacement blower (although not a centrifigal blower) is preferably to the torque curve you get from a turbo in a luxury car for most people. I'd like to build a GS300 with a Supra motor at some point though. A 700hp sedan that still looked bone stock would be a lot of fun.
