hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Thu Dec 21, 2006 9:55 am
A list I put together years ago...
turboturbo exhaust manifoldwastegate (if turbo doesnt have internal wastegate swing valve housing)
downpipe (connects turbo outlet to cat/test pipe)-turbo outlet flange-piping-fittings (O2, wideband O2, EGT)-wastegate return pipe (from wastegate outlet to downpipe)--external wastegate onlytest pipe (takes place of cat, connects downpipe to catback exhaust)catback exhaust (mandrel bent)-piping-muffler
larger injectorshigh flow fuel pumpfuel management (piggyback, retuned ECU [JWT, Enthalpy, Bikirom])ignition management (timing retard control)--over 8 psi
intercooler (front mount)-IC piping (mandrel bent)-silicon hose couplers and transitions
BOV (with flange of same material as IC piping)
oil supply kit-oil pan bung-braided oil lines-oil line fittings-'T' fittings
water/coolant supply kit--watercooled turbo only
gauges-boost-oil pressure-oil temp-water temp-EGT
intake piping (mandrel bent)cone filter
gaskets-exhaust manifold-turbo flange-wastegate
vacuum hoses (silicone or rubber)-'T' fittings
clutch?flywheel?
