kouki munster »
https://forums.nicoclub.com/kouki-munster-u34314.html
Sun Feb 12, 2012 10:26 pm
Since you are running 264 cams, I would run a larger turbo that can take full advantage of the powerband the cams will give you. A t-2 flanged td06 20g(about $800) is almost a direct replacement for the s15 turbo you have now, and flows enough air to make a little over 400 on pump gas and north of 450 on e-85 or race fuel.(it also is a near perfect match for the bc 264 cams) Another good option is a gt30r, but it cost more (I think around $1200 new but can be found cheaper used) and it is a t-3 flange, so you will have the added cost of having to swap to to a top mount t-3 setup, and it will make roughly the same power as the 20g.
