elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Oct 08, 2007 5:03 am
man i feel like a loser for knowing exactly which hose is and where it goes. I need to get a freakin life.
the top big hose the the hose that goes into the the thermostat housing from the lower radiator hose.
the middle left is one of the hoses that hooks onto the PCV valve.. I cant say for sure which one since theres like 3 that are identical. The pcv valve screws into the coolant filler neck.
the middle right one im not 100% sure about, its either the L shaped vacuum hose thats behind the throttle body on the plenum. its a PCV hose that takes vacuum to the passenger side valve cover, hooking the plenum to a pipe that goes under the plenum to the RH VC. If its not that, its a coolant hose on the drivers side TB area..
The bottom hose is one of the low pressure hoses for the PS system, in other words one of the hoses that goes from the fluid res. to the PS pump.
