What hose do I use to flush
izmyttz
Car: 1990 300zx TT-White,
The coolant system? Not just the radiator? I bought a flush kit but I'm not sure what hose to use to hook up the water hose to, to let it run water through the system. I'm going to get a new radiator and then do this before I install it. I'm tired of wasting money on coolant.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
just drain the coolant as the drainplug int he bottom of the radiator (passanger side IIRC) refill add flush solution and run it oer instructions
Wetmyson
Car: Z32
MAKE SURE YOU BURP IT
izmyttz
burp the radiator?
Wetmyson wrote:MAKE SURE YOU BURP IT
tg
ROFL + OWNED
just pull the plug on the bottom, run some distilled water through it a few times, then repeat until there is no coolant/rust water coming out of the drain plug.
Replace plug, fill up, run for a 30 seconds with the heater on, refill, run again for 30 seconds, top up if needed, and fill the resevoir.
izmyttz
i know how to flush the radiator......i''m not flushing it....i'm replacing it..but i didn't want debris in the lines of the coolant system..that's why i wanted to flush it...i'm getting an AMS radiator since they seem to be a heck of a better quality than KOYO. So if anyone has any input on flushing the system then that would be appreciated. It's like asking someone how to flush a toilet and they tell you you have to wipe before you flush.......lol
izmyttz
oh yeah just encase anyone was curious........AMS all aluminum high capacity Z32 Twin Turbo racing radiator.
* Fits all Nissan 300ZX Twin Turbos 1990+. * Triple core - 57 mm - single pass - thicker than Koyo (53mm) * All aluminum construction to ISO 9001 Manufacturing Standards * One Year Limited Manufacturer Warranty - Koyo = none * 70 x 45mm end-tanks - fully polished * 45 fins per square inch allowing for less restriction across the core * Thick walled billet welded neck - vs flimsy Koyo design * Extra thick Flared Inlet and Outlet Pipes allowing for aggressive tightening of clamps * OEM mounting Points - stock rubber insulators used and retention of stock fan shroud (minor trimming of fan shroud required near upper rad hose) * Aluminum Fill plug vs. Plastic for Koyo! * Brass 'T' Fitting Drain Plug * AMS Laser Etched logo * AMS Colour Painted Logo on both sides * 1.3 High Pressure Cap Included
