What HKS clutch is this???
nyamping
Car: 1998 240sx SE
Guyssssssss...I finnaly got a chance to take the transmission off today. Getting closer to finishing the swap....yeah right.....
After blowing the dust off the clutch that comes with the engine into my lungs The clutch is revealed.... what type of clutch this is??? it looks thicker than normal...
I got 2 questions:1. What type of HKS clutch is this?2. Does it looks like it needs replacement? Can I just replace the disc?3. Where can I re-surface the flywheel and the pressure plate?
Rendy
Modified by nyamping at 10:05 PM 8/18/2005
Modified by nyamping at 10:06 PM 8/18/2005
nyamping
Car: 1998 240sx SE
another pix
nyamping
Car: 1998 240sx SE
nyamping wrote:another pix
nyamping
Car: 1998 240sx SE
[QUOTE=nyamping][/QUOTE]
Nismo_Freak
Car: 89 Nissan 240SX
Thats just your typical light duty HKS clutch.
Rated for about 350 PS I believe.
Nismo uses the same pressure plate.
nyamping
Car: 1998 240sx SE
Ok. Thanks. I decided to get a new one. Its the XTD 6 puck. Have you heard of it? Its cheap I can't resist.
Nismo_Freak
nyamping wrote:Ok. Thanks. I decided to get a new one. Its the XTD 6 puck. Have you heard of it? Its cheap I can't resist.
Why you didn't stick with the HKS I don't know.
nyamping
Car: 1998 240sx SE
This HKS clutch that came with the engine has hairline cracks as seen on the picture. So I don't want to take a chance. . I finally got to take apart my engine today. The flywheel is off, front pulley off and the mani as well.. I can see clearly now. Its got thick JDM carbon deposits!!!
