deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Aug 21, 2003 4:44 pm
between bores is reduced .080". i have been running for about 2 months with absolutely no problems. i know of one other ka24e (non-turbo of course) at 91mm bore than has been running for over 7 years. no sleeves, i dont really want to tell everyone what my pistons are but they are from different car manufacture, they have a 36.1mm comp. ht, 2 - 2mm cast iron compression rings, 22mm press fit pin, and are flat top. i have no pics but you can imagine the distance between bores reduced .080" so there is very little room for the headgasket. the headgasket actually protrudes into the cylinder a few thousands. the pistons must be modified along with the ka24e rods. took quite a bit of extra thought and machining processes but still well worth it compared to price of other high comp. ka24e piston sets
