Mark Linkous »
https://forums.nicoclub.com/mark-linkous-u56914.html
Sat Sep 06, 2008 4:04 am
Hello,Unfortunately, there really is not a head unit in your car. With Bose systems, each speaker is powered individually at the source. I suppose by definition, the head unit would be the vehicle information display or nav screen.
Short of adding bass via a outboard amp and subwoofer, there are no easy solutions. While you could certainly pull out the Bose system, get ready to spend and spend. And I cannot say this enough, make sure you check out your car stereo installer. Some are artists, many are hacks. A hack can honestly ruin your car.
JL Audio's Cleansweep might be helpful in your goals as well. Again, this solution would not be cheap. However, the Cleansweep does provide previously unheard of flexibility with Bose systems. Might be just the thing. Adding bass however would be much easier and less invasive.Cheers,ML
