what have ppl paid, machine work?
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
jsut wondering what anyone else has paid for a cleaning, check for straightness, and MAYBE a magnaflux (make sure everything is 100%)? Ill be getting money together over the next couple weeks or so. jsut wondering what others have paid?
thx all!
float_6969
Couple hundred at most, and thats if they have to mill the block.
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
175 to dismantle the head clean, put in new valve stem seals, plain it200 to hone, deck, clean all components and polish the crank
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
250$ for evertything honed, bored, balanced, cleaned. I also had the head o-ringed? <--- Suggested by the machinest. This was done by a guy I know so it was discounted. Plus the old man has over 30 years of experience with turbo chevy's and such so I trust his abilities and suggestions.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
$150 for disassembling and cleaning the head, milling it true, and installing the new stem seals, guides, springs, retainers, and new valves I got. With parts I think it was about $337, but that was for basically a brand new head. There are no old parts left in there.
kapower06
$845 for hot tank, clean all galleries, line-bore the mains, deck,bore,hone, lighten and surface the flywheel, polish the crank, dynamic balance everything as a set, and assembly of bottom end.
boost_boy
kapower06 wrote:$845 for hot tank, clean all galleries, line-bore the mains, deck,bore,hone, lighten and surface the flywheel, polish the crank, dynamic balance everything as a set, and assembly of bottom end.
Tack on a few more dollars and that sounds about right for me for similar services. It all depends on the shop doing the work and their desire to discount their work as well.
Dee
Liquid_Neon
thanks all, some ideas i haven't thought of.
Ill be doing my own disassemble and reassemble, plus i got a shop foreman who builds chevy small blocks. so i figure he can lend a piece of advice or two if i get stuck. Ill be useing mostly OE parts, this isnt going to be some 400+ build. Im aiming for upper 200's, good enough to school most local cars.
Cause once im done with that, im gonna start working on building my suspension even further then my AGX, Pro-kit combo.
Again, thanks! great advice 'round these parts 99% of the time
