What have I done to deserve this? 91 240 clutch problems-help again
240stuff
Car: 1991 240sx 1978 280z 1985 pu
Unbelievable--Have a 91 240 sx, had a mechanic replace slave cylinder, clutch plate, and I think the master cylinder, the clutch burned up in 7 miles, thought maybe he did not bleed the box next to the slave cylinder, had it repaired again by a different mechanic, he replaced burned parts, driven around 200 miles and now this clutch is slipping so a friend told me--into it for $425.plus now and still don't have a car I desparately need and am close to being out of money. I had the engine replaced also with another one with 83,000 miles on it, no problem there so far. What could the problem be?
Altiman94
Car: 1989 Nissan 240SX
take it back to the mechanic. They need to honor their work.
s13sr20chris
for real.is the clutch pedal adjusted too tight?
Touchdown038
Car: Computers, cars, sports
Definitely sounds like the clutch adjustment to me. My guess is it isn't letting the clutch and flywheel fully separate when the pedal is depressed.
