ilikenissan wrote:yeah your car having 217,000K has ALOT to do with it.. I will assure you that your car is putting out no where near those numbers..Unless it was very very babied in which case your car might have 110 crank horsepower.. And I strongly suggest you dont go dyno it to try and prove me wrong or somethin.. Dyno pull's are rough on cars.. But like rip out all the spare crap in your car and replace your plugs and your injectors probally need cleaned really really bad if not replaced... and you might take him.. And is your clutch slipping at all.. Im sure your car has had a clutch put in it at one time or another you should figure out when that was..
aleph1 wrote:the 735i has 182hp 3.4l six. Most likely weights around 3500lbs.
Run some Seafoam in your car to clean out some of the carbon, if it has alot, you will probably notice the difference (and see a huge plume of smoke come from your exhaust). Also get new NGK plugs and either clean or replace your 02 sensor after the Seafoam, they will be coated in carbon.
You can take both cars me thinks, but you should take some precationary measures to make sure, such as what I said above and try to reduce the weight as the other mentioned. Such as removing the spare tire, jack, etc for the race...dont bother with taking apart the interior, just clean out your car.
kyle1911 wrote:where can i get some Seafoam? i assume if i get some it has directions on it... removeing extra weight is in the plans, i have no speakers now ... like 20lbs
todo list so far:Seafoamplugsthermostat?
i have new wires and fluids are good.
thanks for the input
kyle1911 wrote:The reason i am doing a straight line is because they are to ***** to take there moms car into the corners wher i own my own car its my own risk. this will be doen late at night and i will plan it out to the best of my abulity.
Think i can beat the BMW? i thought i could but wasnt sure since ive never seen one moving.power shifting is not a problem, ill try my best lol
What is the advantage to changing my plugs? i have new wires on it and i cleaned the distributor a while ago. the car idles and runs smooth but it sometimes backfires from high rpm down to low.
