What hardware is included with front brakes?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I recently purchased a Q45 front brake kit from a member. He stated that it would include everything; even pads, but all I received were rotors and calipers.
I've been having trouble reaching him and have basically given up. I only payed 75 bucks so I can't complain too much.
The ad that he posted states that he is selling them off of a 92. But the ad had been there a while and when I replied asking if he still had the fronts available. He stated that he had "a" pair of fronts available; not that he had "the" pair of fronts available. The reason this matters is because the information under his avatar states that he has a 94. I've done some searching and found that there are some differences between the years. Here's the ad he posted if your interested
zerothread?id=368840
So I don't know what parts I need to get.
Also who is this Joe guy I keep hearing I should buy my Q45 brake parts from?
Thanks in advance!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.infinitipartsusa.com
The pads, rotors, caliper rebuild kits, shim kits, and calipers are all sold separately.
There is no "front brake kit."
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
So is there a difference between 92 and 94 model year brake parts?
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Late 94 eliminated the electical sensor "brake pads worn" and replaced it with a mechanical "squealer" to inform you it was time to change the pads
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Thanks. I don't think I'll have to worry about that; I'm using these brakes as an upgrade to my 240.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mmm240 wrote: I'm using these brakes as an upgrade to my 240.
So you are running the 4 stud standard brakes on the rear?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Yes, but I'm having the Q discs re drilled
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Much better solution to convert to rear J30/FGY33 calipers and rotors and go 5 stud all the way around.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I don't want to mess with the e-brake situation. And I also have 3 sets of 4lug wheels
