C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Sep 29, 2002 6:51 am
If you want to replace the MAF, you will need to have the ECU modified or have some sort of fuel controller to compensate.
But unless you have a lot of HP over stock, chances are it won't make much of a difference. Years ago, SCC magazine tested a Place Racing intake on an SE-R. The MAF is very similar in dimension to the S13 MAF. They ended up trying to use a MAF that is larger and only gained a small amount of torque in the lower midrange. They figured the power came from a resonance effect, since the cold air section allowed a more continuous resonance through the larger MAF. But peak power remained unchanged. Either way, they said it wasn't worth the money to reprogram the ECU just for that alone.
