what happens in EGR delete???
vincent.wallen
Car: 1990 Nissan 240sx s13 hb stock ka24e
im thinking about doing a EGR tube delete and was wondering what all i can remove with the delete... the thing that the egr goes into on the intake side... vacume tubes coming from it... also do i need to plug any tubes... its a kae... totally stock... thanks
vincent
David s12
Car: 84 datsun s12 ka24 swap
well, follow the egr tube, and watch where it goes
best thing is to buy, or fabricate a egr block off plate, where it goes into the engine
this can be also done, buy gettign a seperate one (in case u f*** up)
and either Jb welding the s*** out of it if your broke, which i dont recommend, or welding/cutting the outside to a flat plate
or you can just make a plate simply, and drill holes for where the bolts go
after you do that just look where all the hoses went, and plug the hard lines.
remove the ghey charcoal canister in the bay, etc. plug it all up wherever the lines go
if you search on here youll find stuff
vincent.wallen
alright... thanks a lot =]
vincent
