What happened when your CAS went bad?
civicsi2
So not sure how often they go bad. But does anyone have an experiences that they could share with me. When it has gone bad what happens? What was the motor doing?
For SR20DET.
SpeedRacer1
Car: 1990 240SX, G35
The motor doesnt run. I havent heard of one going bad naturally. The only CAS I ever saw that was bad was when the laser etched disc had been crunched. The engine never ran with it like that, it just would make loud popping noises.
Hijacker
Car: '92 240sx Convertible
'94 F-150
bad CAS causes either the car to run like crap or not run at all
spider_slayer
Car: S14 240SX
S13 240SX
not to steal the thread from ya......but i was wondering how the crank angle sensor works. i understand that it hooks up to the cam sprocket......but thats it. anyone wanna enlighten me??
SpeedRacer1
The gear that rotates with the exhaust camshaft is connected to a laser etched disc with 360 holes put into it. At the major corners (0, 90, 180, 270 degrees) there are different shaped holes. As the cam spins, it spins the disc, and a laser is shot through the disc. When the laser hits a hole in the disc it sends a pulse to the ECU, the different shaped holes are for ignition of the spark plugs.
Hijacker
'94 F-150
btw, speed. I have seen a CAS go bad naturally. It's a rare case, but it does happen. Just like any other electronic piece, something fries or just stops working and then the part goes bad. But they've always been very old, and been weathered. CA CASes seem to go out more often than SR CASes
