Very well said.bone_stock_240 wrote:you might have to wait longer than 66 minutes. It is still early on the west coast, where alot of the members seem to hail from.
Although I'm sure the karma involved in this will come back and probably kill your motor for something like this, but you can also go to an autoparts store and get a replacement e-clip.A31BLUEMONSTER wrote:check the actuator arm, i did that once with my RB after a highway run, the tiny little clip fried off the actuator arm or whatever and poped off the bracket. you'll have to remove the heat shield if you have one, and be sure to let the engine cool first. just pop the arm back into the hole and and it should be good, in the meantime, ask a buddy to see his extra turbo, and steal the clip.
