doesnt it seem like my engine is sitting WAY too high? before i pulled it, it sat fine, everything fit, hood closed,etc. etc.
i did change one thing, i made my own solid motor mounts out of 3" square tubing, drilled holes, welded bolts, etc etc.
this picture is with them installed right now (notice how high the cam cover is compared to the hood pins)
i did make some 2.75" square tubing mounts once i realized how high it sat. but now if i install the smaller ones, the oil pan is going to rub/hit against the front sway bar.
what did i do wrong?
P.S.
should i just slip the oil pan behind the sway bar and be done with it?
thanks
