what happen to soon full boost??? i need help...
Joe
HOMEMADE240SXTURBO wrote:it it weird that it is the headgasket b/c i was only running 6psi... i just don't want to believe it...
well honestly, what are your other options?
you are burning coolant, or worse its getting in your oil. realistically the only things that can cause that are headgasket or a cracked water jacket in the head/block. and a headgasket is way more likely than a cracked jacket.
immediately check your oil for traces of coolant. coolant in your oil WILL BLOW YOUR ENGINE. IF THERE IS ANY STOP DRIVING IMMEDIATELY.
**** happens. fully diagnose the problem with a leakdown test, then replace or rebuild.
have you been seeing lots of smoke lately? its possible something else is wrong, but i dont know if ive ever seen a turbo fail around the coolant seal and go bad that way.
again you need to do a leakdown test asap
Cjmartz2k
Car: Hunting for a '89 GTR now
You have a blown headgasket and a serious need to attend an english class. ****ing **** it was like reading a 2nd grade foreign exchange student from mexico's sad attempt to write english for the first time.
HOMEMADE240SXTURBO
Car: 1989 NISSAN 240SX KA24E
lol. well it is true. My first language is not english. i barely pass my english classes. But anyway, i'm not even driving it right now. After I've seen the smoke, i went ahead and park it. I'm gonna do a leak down test in the next couple weeks when i go back home. I really just want to part it out and go back to stock.
