sijoko »
https://forums.nicoclub.com/sijoko-u297.html
Fri Sep 08, 2006 8:07 am
The question is: Are the vibes coming from the driveshaft or the rebuilt trans?
I would hope that the problem is with the shaft. The stock unit is a complicated unit with rubber sandwiched between steel.
Did they mark the diff flange and shaft before removal? If the shaft is removed and reinstalled in another position, you could have vibrations. There is a procedure in the FSM that shows how to properly install the shaft.
