What gauges do i need when turboing my car?
240sxka24dex64
Car: 1993 nissan 240sx ka24de
I want to what gauges i need to buy and install to monitar my engine so it does get f***ed up. I no i need a boost controller gauge but what else would you guys recommend??
berman
boost gauge is probly the most necessary. A/F gauge would be good the list is endless
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
big a** tach
its a necessity
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Huge tach, volt meter, air/fuel, oil pressure, fuel pressure, cant forget the nitrous press gauge, egt gauge, ps fluid temp, and boost, but only hook up the boost and just install the rest, that looks cool...
But on a serious note, maybe a boost gauge and get a wideband O2? U dont have to get any guages, it all depends on what kind of turbo setup your going with, if it is a stock sr turbo with a stock actuator, then it will push 7 lbs, not really a need for a gauge, unless you want to see what your stock turbo setup is pushing constantly.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
I'd get a boost gauge and wideband o2, at least thats what im getting
xX RB Xx
Car: SE3P, FC3S, FC3C.
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
get these and you will be fine. boost, oil pressure, water temp, and a wideband o2 gauge. id recommend mechanical type gauges for everything but the wideband, cause the dont make a mechanical o2 gauge.
the reason i say get mechanical cause i have had alot of friends cars with electronic senders fail on them, giving an inaccurate reading. so i guess if you go cheap, get mechanical, if you down to spend the cash, good electronic gauges will be fine, like defi.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i'm a firm believer that the more money you invest in gauges to check your vitals the less money you will have to spend later one if/when your motor lets loose from something you could have helped.
i have.
boostOil pressureOil Temp.Water Temp.Trans Temp.Wideband o2 gauge.my turbo timer and my AFC NEO both display the Volt reading, so i know pretty much everything the car is doing at any given time. only other gauge that might be needed would be a EGT, but i don't think it is needed at the power rating i will be at 500+
blacksrjdm
Flick if you have all those guages already than the EGT would be the next gauge to be sure you are "monitoring" everything you can. EGT will tell you alot, tells you how your turbo is doing, and how efficient the engine is.
bradt
Car: 1989 240SX CA18DET
Boost gaugeA/F gaugeTurbo RPM gaugeFlux Cap Core Temp gauge
After that, you're set.
S13_love
TJG wrote:get these and you will be fine. boost, oil pressure, water temp, and a wideband o2 gauge.
Those and a A/F ratio gauge imo.
biggie
For myself:
Oil TempOil PressWater TempEGTBoost/Vaccum
SAFC2 as well
I bought an Air/Fuel gauge and pillar pod, but decided not to use it. In case anyone wants it -- hint, hint.
trackslut240
Car: 1993 Nissan 240SX
all of the above gauges mentioned plus the most important one...TPMS gauge
DMan II-40
Car: 1995 240SX SE
That's what a wideband is....
