180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Mar 09, 2004 9:49 pm
you'll need some rtv, for the valve cover gasket, a 24mm socket for the cams, a zip tie to hold the chain in place so you won't have to go through to adjust the timing chain, gasket scraper, exhaust and intake manifold gaskets (compatable with the 91 SE-R with the SR20DE), if you're going to replace all the gaskets under the valve cover, remember to replace the spark plug gaskets (sits between head and valve cover) and that should be it off the top of my head.
