what gas should i use
infinityman
Car: infinity q45
1.hey my 95 q45 says i should use the premium grade gas what would happen if i use reguler gas?
2.and sometimes when i turn my car on it runs great and then when i try to take off the rpm wil go all the way up to the middle and the car is only going like 10 mph and thats only on a cold start.
3. Then sometimes when i stop and then press on teh gas my car tends to jerk. why is it doing that?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Dearborn is not that far away, infinityman! Welcome to our outpost.
1.) Premium. Engine will not live very long. Regular and plus only for emergency use. Several posts on this board.
2.) Sounds like you are not waiting for your car to reach operating temperature before you ....ummm...operate it. Tell us more about maintenance history and ATF white paper towel test.
3.) Is it still in Drive?
91+ octane or better!
How well have you maintained the transmission with fluid and filter changes?
Welcome to NICO
infinityman
Car: infinity q45
Tell us more about ATF white paper towel test.
Is it still in Drive?[/QUOTE]
what is white paper towel test and yes its still in drive
infinityman
Car: infinity q45
so
Jesda wrote:91+ octane or better!
Welcome to NICO
i shouldent use 87 octain i just got the car i dont know about trans fluid changes or filter changes
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
infinityman wrote:Tell us more about ATF white paper towel test.
Compare cars ATF to original ATF on a white paper towel. Color degradation is an indicator of ATF degradation.
If it jerks in Drive when you blip the throttle, well...it should. If you mean the rpm climb before the transmission engages, then you need to start saving for an OEM rebuilt one.
infinityman
Car: infinity q45
s
maxnix wrote:Compare cars ATF to original ATF on a white paper towel. Color degradation is an indicator of ATF degradation.
o you are say ing i should save money for a new trans
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, at least allocating for it down the road.
Spend some time reading all the posts by Q45tech. You will have a much better handle on how to maintain your Q45. Most new owners start with new filters and fluids for a baseline.
infinityman
Car: infinity q45
so i should change my fluid and filter
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:Most new owners start with new filters and fluids for a baseline.
What we are trying to tell you is if you think you are having issues with your transmission then take a look at the condition of the fluid and change it and the filter if necessary. Since you just bought the car, you need to do the same to all your fluids.
Are your hesitation issues transmission related or engine related? From your description it could be a MAF or fuel problem.
For the most part your questions are answered by searching and reading posts. Without looking at your car we can only post guesses. Do some searching and reading and try and narrow down your problem so we can help. Good Luck.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Reading the posts will help you in diagnosing your cars behavior and asking the correct questions. Problems are solved by eliminating failure points - usually deferred maintenance. More than 2 or 3 concurrent problems can make a car virtually undiagnosable over the internet.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
One thing for sure, super unleaded only, there is no value in running lower grade.
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
use anything less that Supreme (PREMIUM or SUPER) ... just go ahead and say bye bye fuel pump.... And say Welcome to a junk load of other problems including the fuel Pump. First things... if the car is giving you probs like that , id suggest using your best knowledge. If you dont have a best knowledge, take it to a well trust and CERTIFIED q45 mechanic. Even if it has to go to dealer. Find out all your problems and knock out the major ones once and for all.. Because if you come in here playing the guessing game, then you're not helping the car none. Ive seen Q's just die becuase of not geting things checked out FULLY!!!
Modified by Romeo5k at 11:23 AM 11/14/2006
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Romeo5k wrote: I've seen Q's just die because of not geting things checked out FULLY!!!
Many instances of new members not doing the correct procedures in evaluating the car before they buy, or not updating the deferred maintenence immediately after buying it, or even both.
Seldom a good or inexpensive conclusion.
NHNissanFan85
Car: 1989 Volvo 245DL
If it says premium, run premium. Don't listen to what anyone else may say. Detonation (ping/knock) can destroy an engine like the VH45DE in a matter of seconds if severe enough under the right conditions - and the lower the octane, the more likely you are to get detonation. Running premium is NOT that bad. I did it for years with my turbo Volvos, and I certainly don't make six figures. Sometimes I fill my 240DL up with premium out of habit.
As for cold start issues - just go out and start it 10 minutes early so it warms up. Again, I did this for years with my turbo Volvos. Most cars are much happier at normal operating temperature, and this is pronounced in the winter.
dr-rjp
Car: 1998 I30
[QUOTE=infinityman]1.hey my 95 q45 says i should use the premium grade gas what would happen if i use reguler gas?
3. Then sometimes when i stop and then press on teh gas my car tends to jerk. why is it doing that?[/QUOTPReE]
NEVER RUN ANYTHING BUT HIGH GRADE PREMIUM.
