Dazanion »
https://forums.nicoclub.com/dazanion-u312368.html
Tue Mar 19, 2024 4:43 pm
I have a rogue 2023 SV. I have an LED strip that I am going to install on the hood. I know where to put it, where to ground and route the wires, my problem is, what fuse can I safely tap into in the engine bay fuse box? And is there only 1, or am I missing something, earlier models had 2 boxes, as well as the relay box. I can't see an easy way to go from the cabin accessory fuse to the engine bay, so I need to use one in the engine bay. I thought the left or right headlamp fuse, but that will only operate when the lights are on and I want it to operate independently. I need power when the car is on. Also what amp fuse would i use for the strip in the tap? 10 amp?
