what FPR is used for RB25 other than Nismo?
exodus5547097
Nissan2367
I use a Aeromotive A1000... Worth the money for sure! There is a member on here that bought his used and has been using it for four years!
exodus5547097
Nissan2367 wrote:I use a Aeromotive A1000... Worth the money for sure! There is a member on here that bought his used and has been using it for four years!
what is the part number for that?
Nissan2367
I got mine from Summit Racing:AEI-13101 You will have to buy one -10 AN plug, One -10 Fitting for you feed and 1 -6 for your return. It has a spot for a FP Gauge so i would get one of those too! Also the easy thing to do is get the AN to NPT fittings so you can just use a slip on hose fitting to connect your lines
