What flywheel for Drag & the occassional drifting??
Solow240sx
Car: sr20 powered 91 240sx
Ok guys my fully built sr20 is just abought to go back in my car and the last thing i was thinkin about installing before i put it back in was a flywheel, The car will mostly be dragged, and ocassionally drifted, the motor should be putting down around 500 rwhp, just wandering what would be the best flywheels to go with i Do have the stocker and there is nothing wrong with it, i was thinking about going with the JGY 10.5lb but not sure if it would hurt the car at the track as far as not having enough enertia??.. Can anyone help???
Solow240sx
Anyone??
jr_ss
Car: 95' S14
With 500rwhp it doesn't really matter which one you decide to run... I put a Spec Billet in mine before I swapped my motor in... I'll probably run something of the similiar weight...
Solow240sx
I was pretty much just wandering if i could run like a 14 or 10 lbs one and still be able to launch on wrinkle walls without it falling on its face from not having enough enertia??
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I have the JGY 10.4lbs and I like it. http://www.jgycustoms.com/240sx/clutch.htm
I also have the competition 6pad clutch and it takes 7K clutch drops well.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Ive got a Toda 10.5lb Flywheel in mine.
bruinbear714
I'd get a Toda flywheel.
Solow240sx
And all of you guys cars launch fine without bogging?? I already have the ACT clutch i will be running and i will probably be ordering a jgy 10.4lb flywheel...
DrifterProdigy85
Flywheel size isnt gonna make a big difference on bogging compared to the type of clutch used and how your engine delivers the power.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
This is a touchy subject. Some people I have talked to say the heavier flywheel is best for drag. Some say a lighter flywheel will give you more power making it better. If this is your every day driver car, the 10 lb. flywheel will take away a little drive-ability.
Solow240sx
It wont be a daily, i may drive it to work every once in awhile but mostly it will be a weekend car, and drag car on friday nights...
DrifterProdigy85
I daily mine with the 10lb and its perfectly fine. Doesnt bog down on launches either. If you worried about bogging down, then get a 2 step to launch off of. You should have one if your gonna drag race anyways.
Solow240sx
Sounds good man thanks, the car will deff be launching off a 2 step, i just wasn't sure if a 10lb would matter enough to make it bog.. Thanks agian..
