What flywheel can I use on my Pulsar GL E15 motor ?
Greystroke
Car: 1985 Nissan Pulsar GL (Std E15 OHC) N12 Series
My flywheel is worn out & has to be replaced. Am unable to find a Pulsar E15 flywheel in South Africa & agents are not interested as it's an old vehicle. I heard that a Sentra flywheel will work ? Does anyone know what models use the same / compatible flywheels or the specs for it / casting no / identifying marks ?
centralcoaster33
Car: 1997 Nissan 240SX #5
Look for Stanza and or Maxima flywheels from '85 to '86 or Sentras around '87 to '88. I think it's a part number like 12310. You may need a junk yard... not sure. Have you removed the flywheel and measured the thickness to see if there's room for resurfacing already? I know it's an old car, but if the thing isn't warped, then a resurface is probably the solution you want... paired with a new clutch kit of course.
