joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Fri Dec 14, 2007 5:33 am
It depends...if you go with a turbo, then you're going to want the widest you can get which is the APS. If you have a root's supercharger, ie Stillen blower, then you need some restriction to get max power. The vortech is in the middle.
But for a stock car, I would say that all cat-back systems will put down similar numbers, which is probably 5-8 HP. The G35 has a decent OEM exhaust, but when you start modifying things such as the intake or FI, you need more flow...which will yield more power from an exhaust system. Also, you'll gain more if you do a set of high-flow cats or test pipes. Each aftermarket exhaust has a different sound quality, so you'll want to take that into consideration. The HKS and Stillen sound fantastic. Others, such as the Nismo and Borla sound ok, but can be raspy.
To answer your question, the Stillen would give you the most bang-for-the-buck IMO. It uses a true-dual design to replace the stock mid-pipe and a higher-flowing muffler section. It's also lighter than OEM, which will make a difference in acceleration.
