ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Tue Feb 24, 2009 4:14 am
ok,.....if your wanting to SLAM the car the your best bet is coilovers, if you go with coilovers and SLAM the car, you will need pillowball front mounts that allow for camber adjustment, sold by tein or if you get a decent set of coilovers they will be included and Rear Upper Control(or Camber) Arms, or RUCA's, which will allow you to adjust rear camber, but if plan on going really low you will also need rear toe arms and possibly traction arms, entire sets of arms are avaiable from many different manufacturers, SPL, Megan Racing, Battle Version, Peak Performance, Circuit Sports
for what you are wanting according to you previous post, i would discourage coilovers as they will ride MUCH more harsh, and you may not be tracking your car, look for a good reputable set of springs and struts, something like Tein S techs, or RSR springs, or Eibach's couple them with a good set of struts such as KYB AGX's, which if you want allow for a little dampening adjustmet if you ever do want to track it, oh and STOCK REPLACEMENT STRUTS ARENT MEANT TO BE USED WITH LOWERING SPRINGS, the spring rates and less travel caused by and lower than stock ride height could cause the struts to fail
if you go the spring strut route look for a cam bolt type camber adjuster(your alignment shop sould be able to get you some if you dont know what you need) and i would still recomend Rucas for the rear, if your rear camber cannot be adjuted to within factory specs with the factory arms
all that being said, get what you want to achieve the look and ride you want, then have it aligned properly
after reading your post, yes Tein S techs nd KYB AGX's would be good, you shouldnt need anything else
