what exactly..
ka24deColt
Car: 95' 240sx se
im gonna be building my second ka soon.. but what exactly are the pros of going .020 bore rather than stock? when the compression ratio is the same?
WDRacing
Moved
Ligouri Rd
Car: '96 Nissan 240SX
You will have a 2.4 liter motor instead of a 2.39 liter motor and we all know there is no replacement for displacement.
Really though, if you damaged the cylinder walls it gives you room to have them re-machined and generate a new wear surface. Think of it this way, you can fook up your pistons a total of four times before the block is trash. There are 89, 89.5, 90, and 90.5mm pistons available....although I am not sure a 60 (1.5mm) overbore is recommended.
ka24dewhoneedsansr.
ka24deColt wrote:im gonna be building my second ka soon.. but what exactly are the pros of going .020 bore rather than stock? when the compression ratio is the same?
just got a ka24de from a pick n pull for 153. dollars.i put a socket on tha crank and tried to spin it and it was a little too hard for me to spin.does that nessecerily mean it aint gonna turn over?or could it be that they drained tha oil b 4 they set tha car on site?if so, i aint gonna rip it apart. ill take my chances. tha motor looks good n clean, wit no leaks or blown seals so thats why i got it.hit me up. . .
Brandon93240
Car: 1993 240sx
Stop posting your **** in everyone's threads, it doesn't even address what the op is asking. If you need help with you **** start your own thread.
