What exactly is this part called, and do you have one(WTB)?
benjaminwarfield
Car: 1989 Nissan 240SX
This part sits on top of the tank, and if I'm seeing correctly holds to fuel pump. In addition to changing the fuel pump, I need to _replace_ this part due to serious rustage causing a majorly leaking output (where the hose connects) and shorting out the contacts(the ground wire connection rusted so bad it broke off).
So can anyone tell me what this is called so I can find a replacement? Also, does anyone have one laying around they could sell to me?
Thanks!
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
that is the fuel sending unit u will also need a new o-ring under the unit.I am a parts guy at a nissan dealer is NJanyone need parts or part #s I can hook it up.S-13 part # is 25060-35F01 My cost is $185S-14 PART # is 25060-70T00 My cost is $145
benjaminwarfield
That's fan-friggin-tastic.. I gues the guy that I bought the car from fudged on the "new" sending unit part when telling me what was recently replaced on the car.
Florida240sx
What's your problem?
Acumo
Car: 92 hatch
see how much u get me a new sunroof :D
Florida240sx
electric or manual?
Acumo
Car: 92 hatch
manual one.. im not sure if its aftermaket its on my 90 hatch but its surely smaller than my friends 91 chuki
benjaminwarfield
Well, aside from my perscription not being filled *twitch*...
I'm blowing fuel pump fuses left and right, so I replaced the relay.. Didn't fix it, so I went to the trunk and removed the cover to find that the top(sending unit) was rusted so bad that I don't know how I'm even going to get it off.
Because of the rust, the contacts are rusted up, and the ground wire had broken off. I dropped a dot of solder on the ground after cleaning off a spot through the rust and got it running, only to find that where the outlet hose connects has a major leak.. (which I fixed once with some water weld.). So yeah, i don't want to fool with it anymore.. I bought a new fuel pump and am trying to go ahead and replace that while I'm at it.
dickie
Car: Killer Turtle
that sucks! i hope you get this straightened out. its a sobering reminder for anyone purchasing a car: always double-check everything before buying!
