Bingo!!!! That is what I was trying to get at would it be worth it for the 49.99 that they offer it for... I need to replace my oil pan gasket right now anyways so should I spend the extra money and buy something that possibly doesn't do anything at all.Here is the pic for the KA one, would it be a wise investment?DjPantsSpecR wrote:
is this an alternative to knife-edging?
This company makes baffled oil pans also.I would rather have them do it since they claim they know what there doing. I don't know how oil flows in a baffled pan. I do know that Morrosso sells a doit yourself baffle conversion for almost any make/model oil pan.DjPantsSpecR wrote:i dont think its really worth it without a baffeled oil pan with the louvers... but for 50 bucks...
Yeah but if the baffles aren't incorporated properlly (ghetto rig) then the the oil sump itself cant draw oil consistently.DjPantsSpecR wrote:oh yeah baffles really arent that hard to lay down, you're just trying to slow the oil, or not slow, but rather restrict the oil from sloshing. side to side baffles for turning Gs and front to back for accel/decel
it would be interesting to note how much of the oil pan is full to see if the counterweights even really contact the oil.
but we're talking in fractions of a pound of oil here...
this isnt entirely credible, but ive recently read that every 1 lb you subtract from the rotating assembly is worth about 2.7 ponies...
but by those standards a fidanza would make 27 horsepower
so the ratio has to be off somewhere, so i'm saying this might be a .3 hp gain...
Bigvinnie wrote:Came across this web site recently on scrapers. Just wondering if there are any advantages to purchase something custom like this for the KA.Also claim to use highly durable vibration absorbing plates, do you guy's think there is any truth to this??????http://crank-scrapers.com/prod01.html
This is supposedly there dyno proven claim on a 2.4 litre srt-4.
DYNO PROVEN *For SRT4 owners that have removed or want to remove their balance shafts When you remove the balance shaft assembly from the SRT4 (or other 2.4's) you end up with an oil pan that is a bath tub that allows the oil to move all around and cause large windage losses. The stock oil pan is actually a quality piece -- cast aluminum -- it just needs some oil control hardware.
We make a dual-windage tray (Patent Pending) with louvers and lower baffles with swinging doors. It attaches to a modified crank scraper (steel or Teflon) framework that has bridges across the crankcase. The dual-windage tray has a top louvered section that can be adjusted to closely follow the rotating assembly. Underneath this louvered tray is a second larger tray with offset drain holes. The trays are separated by a gap of 4.5mm. These drainage holes and gap allow the top louvers to quickly direct the oil out of the path of the rotating assembly. Conversely they also help to isolate the rotating assembly from splashing sump oil that would otherwise come through the louvers.
Another advanced feature are the four attachment baffles that hold the windage tray assembly to the scraper frame. These are solid plates that help to segregate the piston bays. Why? When one area of the crank has a high concentration of oil in the windage cloud the crank acts like a propeller and distributes this oil along its length. By closing this path off the oil cloud is instead focused into the tray louvers and of course the crank scraper. You can see this type of feature in the Ford Zetec sump and other racing engines.
We also make a special washer that covers the oil feed line to the balance shaft assembly. You need to block this hole when you remove the balance shafts. This comes with the kit, of course.
Yes, the SRT4 came with a scraper from the factory. The picture below illustrates it on top of our Teflon insert so that you can compare the degree of rotating assembly coverage. There really is no comparison.
Bigvinnie wrote:Bingo!!!! That is what I was trying to get at would it be worth it for the 49.99 that they offer it for... I need to replace my oil pan gasket right now anyways so should I spend the extra money and buy something that possibly doesn't do anything at all.Here is the pic for the KA one, would it be a wise investment?
DjPantsSpecR wrote:dude, for 50 bones im about to make one... wait i'd jsut mess it up
i dont think you're gonna feel any power gains, but you can brag to your friends you got a crank scraper, so for 50 bones i vote yes
I do plan on making a windage tray for the KA -- it is complicated because there is more than one version of main bearing caps, never mind the different pans. There are a couple engines in front of it that I am currently doing setups for, then I will be able to work on it. I am not sure what I would charge because I am not sure what is possible/practical. The other setup prices I have now are typical, though.Bigvinnie wrote:Thanks for the info Kevin, it gives a little more first hand experience on the product which is what I was looking for. How much would you charge to make a baffled pan for the KA, and in your opinion is it worth it? I noticed you don't have one for Datsun/Nissan, but you make some other custom ones for other make and model vehicles.
I understand the main bearing caps, I believe there are a total of 4 different versions z20 uses really small main bearing's (same as the L20B),then you have the z22/24 version in main bearing's, then there is the KA24e uses slightly larger main bearings than the z22/24, then there was the completly redesigned main bearing cap for the KA24de(that one looks as if it would be the hardest to design, Good luck). I will be picking up one of your scrapers after I'm done with my christamas shopping......Kevin Johnson wrote:
