gone2long »
https://forums.nicoclub.com/gone2long-u189547.html
Tue Aug 23, 2011 2:10 am
... On the SD 23 and 25 diesels - Understood. - From what I have found out on the net, these diesels were never sold in the US, but, it would seem that, if such motors were engineered to fit the same trucks designed to take the Z22 and Z24 engines (1983-86 720) then, they should fit any truck that can take a Z22 or Z24. Of course, this is just conjecture. Tell me what you think.
... On the Z22 and Z24, I hope you are still looking into this. Tell me what you find out.
... Also, let me reiterate that my truck, which is probably a 1979 model (see my other threads for more on that) was designed to accomodate an L20B or an Z20 engine. Since it actually has a Z18 engine in it (never stock in the 720) that would suggest a relative degree of interchangability in these engines back in the early 1980s. This is worth taking note of.
... Lastly, getting back to the idea of swapping in an L18, Z18, L20, or Z20 from a Bluebird, Silvia or Skyline, another thought occurred to me. Why would the original vehicle matter? The engines in the swap vehicles would be the same as those used in the early model 720s. However, the donor car and the receiving truck chassis would be different. So, the issue would essentially be ALLIGNING the car engine to the truck transmission, no?
Please pardon my ignorance on this issue because I am not a mechanic, but it seems that, if these various cars and trucks were designed to accomodate the same engines; then, the only mitigating factor in terms of their transferrence from one vehicle to another would be how each "donor" motor would "fit" under the hood (meaning attach to the engine mounts) of the reciving vehicle and how the donor engine would allign to the receiving vehicle's transmission.
In other words, in vehicles which have been designed to accomodate simlar engines, the location of the bolts and holes on the various engines and various types of transmissions should all align. This would seem to be the case, even if the donor engine were in a 2x2 vehicle and the reciving tramsmisson was in a 4x4. The major question then would be as follows: When fitted under a hood and onto a receiving chassis and motor mounts, would the donor engine align with the receiving transmission. Am I right on that?
If the above is true, then, it would seem that an L18, L20 or Z20 car engine should "fit" my 720 truck transmission. However, it might very well not "align" to the transmission once fitted onto the existing engine mounts and chassis.
Again, however, there seems to be a lot of leeway in terms of fitting these various older engines to the various chassis. As noted earlier, I have a truck designed to accomodate a L20B engine, but I've got a perfect fit with a Z18 (which was never stock in any 720, anywhere).
Get back to me on all this, if you can spare the time.
Best regards,
G2L
