300zxstanced »
https://forums.nicoclub.com/300zxstanced-u226373.html
Fri Oct 18, 2013 10:21 am
If you cant pull the motor yourself, it will limit you to other things that can be done. If you can pull it yourself then its a great time to fix a lot of things while it is out. All in all I would only pull it if you can do the work yourself, it will save you tons of money. Other things that you will probably want to change while it is out are oil pan gasket, rear end seal, core plugs, egr if bad, engine harness, water pump, and all rubber hoses. Dont forget that your exhaust, and trany will be out also. So think of it as a good time to build a reliable NA, pick up a beater and roll up your sleves, and keep budget and time in mind.
