what engine should i use for cheap good performance?
ybot13
Car: 1990 nissan 240sx
my ka24e which i currently have in my s13 or a ka24de swap with turbo or a sr20det?
Doya
Car: '95 240sx KA-T
If your KA24E is in good shape then boost it. Just don't get an SR20.
ybot13
my ka24e has 130,000 miles runs in good shape for a 19 year old car. idk if i should rebuild motor and turbo or put in a ka24de and turbo it. do you think there's a performance difference in a ka24e/ka24de
Doya
Car: '95 240sx KA-T
Not that big of a difference where it would be worth it to swap in a KA24DE. Lots of people boost their KA24E. Just do a compression test and see what the numbers are. If it turns out good, then boost it
neverlift
clearly the de will yield more power per psi, that is largely due to the higher compression ratio. An e motor at the lower 8.6:1 and 9.1:1 compression is more"suited" for boost.
ybot13
thanks man i think you convinced me to turbo my ka24e
Doya
Car: '95 240sx KA-T
Cool. Why don't you check this thread out zerothread/317694
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
im all for boosting the ka bro, but just do it right and please keep in mind that most often the words "cheap" and "good performance" are mutually exclusive
livinglegend2100
single slammer man. DO IT
SlIp'n'sLiDe
Car: 240
Sohc would be sweet,and this way you don't have to buy a different motor which = money for turbo parts.
Just m y.02
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
keep the sohc...if your looking for cheap, like you stated, I fear that you will stop at just the de swap, and at that point depending on the condition of that engine it could be possible to have gotten no gain what so ever. someone posted a link to a build, you should read it. if you ask me that dude spent to much money and i hear he is slapping a supercharger where the intake plenum used to be....ahh damn it, thats my build
