biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Mon May 03, 2004 9:30 am
Well, it's almost that easy, you can check for play (not sure the right term here off the top of my head) of the rod bearings by trying to wiggle the rods from below and see if you can, normally you shouldn't be able to or at least not noticibly so.. but yeah to actually check the bearings just unbolt stuff.
Now, there is a REMOVAL sequence for the main girdle / crank caps in the FSM (page EM-34, 88 in the non-broken PDF):
Front                               Rear4         8         9         6         23         7       10         5         1
(when looking from below, obviously, or when the engine is flipped over on a stand)
the rods don't really matter which order you take them off.
Assembly is, as they say, the reverse order of disassembly. (or see FSM EM-41)
