What engine do I have?
canadian240sxBC08
Car: 1989 240sx
I have an 89 240sx, how do I know what engine is in it, is there a specific marking on it or would I have to look at the serial #. thanks for the help.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Moved
Hijacker
Car: '92 240sx Convertible
'94 F-150
You might want to try doing a little research first.
But so long as the car is bone stock, you have a SOHC KA24E.
And the stock motor should be listed on the VIN plate.
pdub240
Car: 89 240 sx
if u look between the exhaust manifold and valve cover between number 2 and 3 cylenders its stamped ka24e but if its a 89 chances r its a ka24e sohc
Goldeneagle
Car: 1992 240sx Coupe
Hijacker wrote:You might want to try doing a little research first.
In addition to the above. Look at the vin plate in the engine bay, you will find KA24E or KA24DE stamped on it.
As mentioned above, if your car is stock you will have a KA24E.
Click here to see what a KA24E, generally, looks like.
Click here to see what a KA24DE, generally, looks like.
Modified by Goldeneagle at 10:08 PM 7/1/2008
Kalypso
your starter internals and your alternator will work on a redtop sr20
(random)
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
Kalypso123 wrote:your starter internals and your alternator will work on a redtop sr20
(random)
canadian240sxBC08
Car: 1989 240sx
is the KA24E worth Rebuilding, and turboing?\
and does anyone have a site link or something to help me get rid of the AC unit, it doesnt work and I just want it out.Thank you for the help so far
sticky_steve
Car: 1991 300zx
2003 350z
What about how to tell what year ka24de i have. If any one has noticed, but the valve covers are different. The 91-94 valve cover has 3 bolts across the top and 2 bolts on the back, and the 94-99 has 2 bolts on top and 3 across the back. So thats leads me to believe that the heads are different. So where's the serial number on the DE to tell exactly what year it is.
