qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Mon Oct 20, 2008 7:49 pm
Hmm, done a lot already .......
1) 5 speed transmission would be awesome2) Few add-ons to the stereo system, nothing major and definitely NOT heavy (I want speed!)3) I want to upgrade my methanol injection, higher output pump.4) Clean up some of the existing installation, oil scavenge pump, gauges, wideband O2, ECU emulator, etc. I continue to mess with and tweak stuff so I have wires and harnesses running all over the interior of the car and the trunk...5) And if I win the lottery I'm pulling the engine and doing a complete overhaul/upgrade. Lower compression, forged pistons, etc, etc. Want to build it to handle huge boost.
Twin turbo wouldn't be much more difficult that what I did. You would want to join the compressor tubing in the rear just after the turbos and run one pipe. The exhaust is easy as it's already dual. A little bumper mod to match the dual exhaust if you want it to run out each side. Might be able to put them where the stock resonators are if they are little turbos and then just run both pipes out of the OEM opening. Been tossing around the twin turbo thing for a while myself... The build was fun and very satisfying, when/if budget allows I may want to do that to mine. I think the 5 speed would happen first tho.
