Yea, as stated above, Z1 sells the same kit for $394 and it's for sure OEM, but it doesn't include the drive belts. You will also need the idler pulleys, about $150 more. So, this is probably about $45 cheaper than a comparable Z1 kit.aroche25 wrote:Thanks for the help! Ill be getting to this early next week. Is this a fair price? http://cgi.ebay.com/ebaymotors/300ZX-Z3 ... vi-content
marty1mc wrote:Yea, as stated above, Z1 sells the same kit for $394 and it's for sure OEM, but it doesn't include the drive belts. You will also need the idler pulleys, about $150 more. So, this is probably about $45 cheaper than a comparable Z1 kit.aroche25 wrote:Thanks for the help! Ill be getting to this early next week. Is this a fair price? http://cgi.ebay.com/ebaymotors/300ZX-Z3 ... vi-content
IMHO, if it hasn't been done in 60K miles, and there are no plans to do them again untill another 60K miles, then they should be done.marty1mc wrote:I understand. No, you don't HAVE to get the idler pulleys. But, if the bearings on your tensioner are toast, then those probably won't be far behind. You could wait until you pull it down, and inspect. If you spin the idler and it sounds gritty, then replace them.
Good points, but I only quoted this part. While technically the weights are the same, there are better products for the transmssion avaialble. I've had great luck personally with Redline MT-90 for the transmission, and 75W-90 for the diff. For those with worn out syncronizers, MTL may work better.onehitfix wrote:since youll be dropping the transmission in order to get to the rear main seal i would suggest draining and replacing the transmission fluid and while youre at it i would replace the rear diff fluid also (as both dif and trans take the same weight fluid).
