DoinkMobb »
https://forums.nicoclub.com/doinkmobb-u83966.html
Sun Feb 06, 2011 11:47 pm
I mean besides the obvious non-existent springs that I can't buy anywhere.
I finally decided I've had enough of my 190K old suspension. The struts absolutely need to be changed out, they're beginning to scare me. I bought some Tokico blues which I'll be using with 190K springs. Probably not the best pairing, but unless someone wants to donate some less used stock springs to me, that's what I'll be using.
I'm assuming it would be wise to replace the dust boots, mounts, and any bushings associated with the struts. Anything else critical that I should look into replacing while I've got the struts out? I'm sure the entire suspension needs to be redone, but I just need to get the handling up to "adequate" instead of "100% OEM quality" right now. This needs to be my backup car so I'll have something to drive while I'm ripping apart my Impreza.
