what else do i need to make my 280 carbed
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
ca240sxcoupe
Car: 1989 240sx w/ca18det, 1978 Datsun 280z
i went to the junkyard today and found a carb. intake manifold for the 280 and i would like to know what else is needed to turn my fuel injected 280 into a carb. 280...just askin if anyone knows.....
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
carbs, manifold, cam escentric and mechanical fuel pump or a low pressure electric pump
Tell us more - I'm doing the same to mine.
nuinqua
Car: 1972 Datsun 240z
Is there an advantage of carbs over fuel injection?
evildky
06 Nissan 350Z GT
carbs are tunable, bosch L jetronic sucks in general
ca240sxcoupe
^ word....especially if you get triple webers or triple mikunis.....but you gotta pay to play......
ca240sxcoupe
hey evildy, instead of a low pressure fuel pump, couldnt i use the stock fuel pump from the 280 but with an adjustable fuel pressure regulator to turn the pressure down?
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
ca240sxcoupe wrote:hey evildy, instead of a low pressure fuel pump, couldnt i use the stock fuel pump from the 280 but with an adjustable fuel pressure regulator to turn the pressure down?
I don't think there are FPRs capable of turning down a 40ish psi system to the required 10psi system. But I could be wrong.
evildky
06 Nissan 350Z GT
AZ Bum is correct, and if you're running SU's they run at about 2.5 psi! That's why there are hgih pressure pumps and regulator as well as low pressure pumps and regulators, anything over 3 or 4 psi will overpower the needle valves in the SU float bowls
ca240sxcoupe
ooooooooo ok i got cha.....
Return to “Datsun Z Forum”
